Interstate RPM
Old Dec 21, 2007 | 12:33 PM
mpost5121's Avatar
Interstate RPM
i just got back from a little road trip and right off the bat i noticed that on the interstate @ 75MPH my car was runnin about 3400RPM is that high. i dont know if this car has different gears and i am the 4th owner of the car so the previous owner does not know either. any feedback would be helpful thanks
Old Dec 21, 2007 | 12:57 PM
JakeRobb's Avatar
Super Moderator
What kind of car is it? We'll need to know the year, model, engine, and transmission (auto or manual).
My 2002 Z28 M6 runs 75mph at a little under 1700 rpm.
Old Dec 21, 2007 | 01:00 PM
mpost5121's Avatar
oh yeah sorry about that .its a 94z auto
Old Dec 21, 2007 | 01:01 PM
JakeRobb's Avatar
Super Moderator
Does the shift lever on the console allow you to select "1"?
Old Dec 21, 2007 | 01:05 PM
mpost5121's Avatar
yep aftere i noticed that it was really high i took it off the interstate went through all the gears. everything is workin fine.
Old Dec 21, 2007 | 01:07 PM
JakeRobb's Avatar
Super Moderator
I'm not asking if it's working -- I'm asking if it's an option. Some auto cars only allow you to go as low as "2", and that's an indicator of which rear-end gear ratio your car came with.
My guess is that it's not shifting into overdrive.
Old Dec 21, 2007 | 01:08 PM
Green96Z's Avatar
What he is getting at is if it isn't, that means you have the 2.73 rear end ratio. Another way to tell what rear end gears you have is look for the RPO codes on your driver door. GU2 means you have 2.73s, GU5 means 3.23. But even with 3.23s, 75 mph @ 3400 RPMs seems high. Are you running aftermarket gears? Does it seem like the engine is actually running that fast? If not, it could be your speedo is off.
Old Dec 21, 2007 | 01:12 PM
mpost5121's Avatar
yes it goes to "1" and the code is GU5. and i checkd the speedo on the way back with a friend was about 2-3MPH off of the 06 Gran prix. and idk if i have different gears. i might but i did not put them in and i have not checked it out at all..
Old Dec 21, 2007 | 01:13 PM
mpost5121's Avatar
and yes its goin into OD
Old Dec 21, 2007 | 01:18 PM
Z28SORR's Avatar
So the only thing left is gears!
Old Dec 21, 2007 | 01:22 PM
mpost5121's Avatar
thats what i was thinking too i just didnt know if the lt1 ran that high on the interstate. i dont have any friends around here with lt1's so i couldnt just check with them so i just askd it on here
Old Dec 21, 2007 | 01:24 PM
JakeRobb's Avatar
Super Moderator
A stock GU5-equipped LT1 A4 in overdrive should run about 2200 rpm at 75mph.
Go hop in the car, go somewhere nice and wide open, and do an acceleration run until it shifts into second gear. Note the MPH and RPM when it shifts, and come back and tell us what they are.
If you have room, do the same thing for the 2-3 shift.
If my math is right based on 3400rpm in OD at 75mph, your gear ratio is about 4.9:1, which is absurdly high. I don't think they even make a gearset that high for a 10-bolt rear end!
What size tires do you have?
Old Dec 21, 2007 | 01:27 PM
mpost5121's Avatar
i have the stock camaro salad shooters. and what not.. ill go do that test a minute and cme back iwth the results
Old Dec 21, 2007 | 01:28 PM
JakeRobb's Avatar
Super Moderator
Not asking about the wheel size. The tire size. It's on the side of the tire. It'll be something like 245/50R16.
Old Dec 21, 2007 | 01:36 PM
JakeRobb's Avatar
Super Moderator
While we wait for him to come back... somebody tell me what the stock shift point RPM is on an LT1. 5700?
