How Do The Pedals Come Out
i've got all the bolts taken out, and the pedal assembly is loose from all the brackets....HOW DO I GET THEM OUT OF THE CAR!!!!!
i need to remove these inside the day, so if anyone has some quick help, it would be appreciated
Re: How Do The Pedals Come Out
You might have to take out the steering column if you can't wiggle them out of there, 6-spd pedals are harder to get out, I know from experience, I spent a whole day under the dash working on pedals and drilling holes for the 6-spd conversion.
I did a 6 speed conversion and I did the pedals without removing the steering column. I ended up breaking off the gas pedal on the 6 speed pedals. The pedal swap only took a couple of hours. They can be a bitch.
