How do I change my rear right blinker?
My rear right turn signal bulb has burnt out, and I have have no idea as to how to change it. Any step by step instructions?
Re: How the hell do I change my rear right blinker?
OPen truck lid and move back panel cover buy hood latch... There are pastic butterfly nuts holding the lens.... After removal of nuts... pull the taillight to the back and it pops out.... then twist the pigtail assembly to remove from taillight .....Remove bulb and replace......:)
that basically it...... |
Yep, it's really easy.
Don't forget to flush the blinker fluid...
oh ok, so after I remove the plastic butterly nut, the light will pop off if pulled from both side, and I'll be able to access my bulb?
Thanks for the input guys |
The whole lens will come off, once you have the nuts removed.
