High Capacity Fuel Tank 97 Z/28
Old 03-07-2018, 03:05 PM
97rebuiltZ28's Avatar
Lightbulb High Capacity Fuel Tank 97 Z/28
Ive got an interesting case here. The last times I filled up my fuel tank I put 17.6 gallons in, the time before that 16.8, and before that 17.2 all at different gas stations. Do I have some kind of bigger fuel tank? It looks stock underneath but I’m not sure.
I know that the early camaros, including mine, have a 15.5 gallon tank stock and the later cars had 16.8 gal tanks.
97rebuiltZ28 is offline
Old 03-07-2018, 03:43 PM
DrewHMS97SS's Avatar
Re: High Capacity Fuel Tank 97 Z/28
Check underneath to see if you have a plastic tank, which would indicate the larger capacity. The metal tank would be a silver color, plastic tank black. I have not been able to fill mine up more than about 16.5 gallons (plastic tank) so I am not sure how you are getting over 17. My best guess is that you coasted in on fumes and filled the neck by squeezing the pump until gas came out the cap.
Take the heat shield off under the tank and snap some pics. It should be pretty easy to see if what you have is stock.
DrewHMS97SS is offline
Old 03-07-2018, 07:41 PM
I checked, mine is whitish gray but it feels like plastic. The gauge was about a fourth of the way between the Empty and 1/4th mark on the gauge when I arrived at the gas station. And it was not overflowing when I topped it off.
Old 03-08-2018, 10:52 AM
Grey sounds like the metal tank. Were these at different gas stations? Maybe a station had incorrect metering?
Can you snap some pics?
Old 03-08-2018, 09:58 PM
I filled up at 2 different stations. I’ll try to take some pictures tomorrow
Old 03-09-2018, 02:01 PM
Here is a picture https://imgur.com/a/zD88y
Old 03-09-2018, 02:35 PM
That's not the fuel tank - that's the floor of the hatch compartment. The fuel tank is in front of the hatch compartment, and above the muffler.
Drew has a photo of a plastic tank in this thread:
https://www.camaroz28.com/forums/lt1...l-tank-886314/
This is a photo of a small part of the bottom of a stock metal fuel tank. It's the only one I could find in all my photos of my car. Ignore the fitting and the line in the photo - that's added to feed a second fuel pump.
Attached Thumbnails High Capacity Fuel Tank 97 Z/28-dcp03576.jpg
Injuneer is offline
Old 03-09-2018, 03:19 PM
That makes me feel dumb. Oh well. Thanks for the replies, next time I get it on a lift I’ll take off the heat shield like he says above and take some pictures.
Old 03-09-2018, 03:58 PM
Now that you point it out, I don't have any pics of the tank from under the car, just the ones looking in with the filler neck. I'll grab some pics when I get after the ABS sensor on my rear end, but no promises on time!
Old 03-19-2018, 02:39 PM
https://imgur.com/a/pRyd8 Here is a picture. It’s been awhile and I took this one just by squeezing up under the passenger side rear fender. The tank feels metal and is whitish like you said.
Old 03-24-2018, 01:27 PM
That looks stock. I have no clue how you are getting 17 gallons in it.
Old 03-24-2018, 10:44 PM
I don’t either. You did answer my question about if it’s stock or not so thanks for that!
Gio93z
Parts Wanted
06-02-2005 10:13 AM
BTM
11-29-2004 11:49 PM
Black6SpdTA
3rd Gen / L98 Engine Tech
05-26-2003 11:45 PM
Quick Reply: High Capacity Fuel Tank 97 Z/28
