interior a/c switch replacement
Old 05-15-2014, 09:23 PM
motorman120's Avatar
I have to replace the interior a/c control head. How or can the front dash panel come off? Or do i have to remove the entire dashboard to replace it.
This is on a 94 lt1
motorman120 is offline
Old 05-16-2014, 07:40 AM
Re: interior a/c switch replacement
Do you have a Firebird or a Camaro?
Injuneer is offline
Old 05-16-2014, 01:39 PM
guess I should have indicated it was a Camaro, sorry
Old 05-16-2014, 03:49 PM
Don't have a Camaro, and the Firebird procedure is much simpler - pull the surround off. Maybe someone with a Camaro can help out.
According to the 94 factory manual:
Remove "bezel assembly, instrument panel cluster trim plate". The diagram shows it as the entire plastic piece that surrounds the instrument cluster, HVAC panel and headlight switches. The written steps indicate 4 bolts holding the bezel to the dash carrier. The diagram shows the two bolts on the bottom edge, but does not locate the additional bolts.
Disconnect temperature control cable electrical connector and vacuum wiring harness electrical connector.
Remove screws that hold panel to the dash
You can download a copy of the 94 factory manual here:
LINK: 4TH GEN SERVICE MANUALS; 82-02 PARTS DIAG; 99-02 WIRING DIAG - Firebird Nation
Injuneer is offline
HectorM52
06-23-2016 08:42 PM
QuickSilver02
04-07-2015 11:12 AM
alphaauto
02-05-2015 05:25 PM
01-23-2015 01:13 PM
pologreen97z
12-02-2014 10:42 AM
Quick Reply: interior a/c switch replacement
