HELP need gasket part number - CamaroZ28.Com Message Board
Old 10-09-2018, 02:22 AM
Boy am i having trouble finding the correct valley cover gasket ( or does it have another name) for a 1989 iroc(5.7ltr tpi l98 engine code 8 )here in New Zealand and the correct inlet gaskets ,does any of the group happen to have the part numbers for these gaskets , even a picture would help or recommend which ones to get,,thanks, its driving me nuts
THMAX is offline
Old 10-09-2018, 10:48 AM
Super Moderator
Re: HELP need gasket part number
I think it would be to your advantage to set up a “signature”, and add your location to the information that shows up under your name in your posts. This guide was set up for 4th Gen vehicles, but shows the critical info that helps people provide you with accurate responses.
https://www.camaroz28.com/forums/lt1...nature-879835/
I will also caution - the majority of the members seem to be 4th Gen owners, with different engines than the original “small block” Chevrolet engine. May delay responses to your questions. Hopefully a Gen1 SBC owner will see this and respond. Wish we had move active members, but interest in these cars is simply not what it used to be.
That said, let me see if I can find a parts guide applicable to your engine.
Injuneer is online now
Old 10-09-2018, 12:23 PM
Super Moderator
The problem is calling it the "valley cover". The L98 TPI uses a 2-piece intake manifold. Lower intake manifold bolts to the heads/covers the valley, upper intake (plenum and runners) manifold bolts to the lower intake manifold. There is nothing like a classic valley cover used in many other engines.
This is a complete manifold gasket set (Corvette L98 is same as Camaro L98):
https://paceperformance.com/i-513415...pi-engine.html
Here's an article on solving the L98 intake manifold leak issues:
Repairing L98 Tuned Port Intake - Corvette Fever Magazine
Old 10-09-2018, 12:33 PM
Super Moderator
Hold off on the gasket kit I linked above. Not sure it there were not some minor differences in the Corvette vs. Camaro heads.
But the concept will be the same.
Old 10-09-2018, 12:59 PM
Super Moderator
When I talked to Pace Parts, they claimed the above set was only for the Corvette, and GM had discontinued the set for the Camaro. This one looks better:
https://www.summitracing.com/parts/m...ro?prefilter=1
Old 10-13-2018, 09:50 PM
Thanks Injuneer for your time ,i have since worked out that up to 1987 they used two rubber gaskets at each end of the intake and it seems after that they just used sealant ,go figure, that one on summet racing is basically the only one ive seen with the end gaskets
THMAX is offline
Old 10-23-2018, 12:42 PM
ZZ
ZZ's Avatar
Those rubber gaskets come in most small block chevy gasket kits, and most of them end up not being used because they are prone to leaking. It's better to use a 1/4" bead of permatex ultra black RTV sealant without the gaskets.
ZZ is offline
rasputin
03-25-2008 11:44 PM
5.7LT1Formula
01-23-2005 08:23 AM
TEAL94Z28
01-28-2004 12:54 PM
TEAL94Z28
01-27-2004 05:21 PM
Quick Reply: HELP need gasket part number
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
