Headlights Screwed Up?
Old Sep 7, 2006 | 05:25 PM
NavyBlueFanatic's Avatar
So, if I put on my head lights they all go on. They are all dim except for one on the right. I have to use the brights. The thing is, only the right side works with the brights. I dont know whats wrong? My friend said its the headlight switch. Im sick of driving around like this! I also lost both fogs but, thats just the bulbs. I need some help ASAP!
Old Sep 7, 2006 | 07:03 PM
Dave89IROC's Avatar
Re: Headlights Screwed Up?
bad ground
Old Sep 10, 2006 | 01:07 AM
floraelianor's Avatar
I had the same problem, In my case the head lamp module circuit had a bad IC. Before we started loocking within the module, we checked out all the electrical wiring by ellimination. Like swapping the left wiring to the right and see if we get the same problem.In my case no matter what we tried the problem was always within the driver headlight. Consequently, we decided to look inside the head lamp module circuit. To make sure the problem cam efrom the module, I was lucky to have a friend having a 1997 TA with a working head light which allowed to swap the two modules. Then I was sure that problem came from the head lamp module which is located abobe the driver fender (or behind the original air box filter place, above the driver fender)
Old Sep 12, 2006 | 01:24 PM
So, what part do I need?
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
Greg88
Sep 20, 2015 07:14 PM
jackpawt883
Sep 10, 2015 08:53 PM
Aug 17, 2015 09:50 AM
