Abs, brake and asr light lit on dash
Old 11-17-2018, 05:46 PM
Phoenix-z28's Avatar
I have a 98 camaro. Abs into and brake light stay in. Found tear wire for speed sensor was cut. Spliced back together. Drove the car light went off for a couple minutes. All three lights are back on while I drive. I have c6 18 inch rims in the back and 17.s in the front. Could this be a cause for the abs inop, brake and asr to stay lit.
Phoenix-z28 is offline
Old 11-17-2018, 08:47 PM
Prominent Member
GaryDoug's Avatar
Location: Born on the Florida West Coast, now where can I retire?
Re: Abs, brake and asr light lit on dash
Possibly. How long does it take before the lights come on? Many ABS faults are almost immediately indicated but not for unbalanced tire sizes. I think it would take a bit of driving first.
GaryDoug is offline
Old 11-17-2018, 10:16 PM
The fact the front and rear wheels are different diameters wouldn’t affect the braking system. It is the outside diameter of the tires that is important. What size tires do you have on each of those wheels?
Injuneer is offline
Old 11-17-2018, 10:20 PM
Prominent Member
GaryDoug's Avatar
That's what I meant to say ;-)
GaryDoug is offline
Old 11-18-2018, 01:25 AM
Front. 245/45zr17 95w
rear 245/45 r18 96w
Old 11-18-2018, 05:34 PM
The 1” larger tire diameter in the back may be enough to throw things off. Best thing to do is have the EBTCM scanned for codes. That will tell you what is causing the problem.... better than guessing. It's very complex system.
Injuneer is offline
firebirdStud
11
04-10-2010 03:30 PM
95Z28LT1-PA
17
04-03-2009 06:07 AM
Casey_SS
9
02-28-2008 04:34 PM
Dimoncutr
05-19-2005 11:08 AM
00blky87fb
V6 Tech
01-26-2005 06:45 PM
Quick Reply: Abs, brake and asr light lit on dash
