95camaroinok |
05-06-2008 09:43 PM |
hes got a 3.4, it takes a regular style thermostat... To answer the OPs question, yes, the themostat could be bad already if they flushed the system, it could have gotten clogged up.
To answer your original question ---- On the left cylinder head (drivers side), on the side close to the front, there is a temperature sensor for the gauge on the dash. Take that sensor out while the engine is cold and procede to fill your radiator untill it starts running out the hole. ***Might be a good time for a second set of hands if you have someone around that can help*** When it starts pouring out, put the sensor back in and continue to slowly fill your radiator, let it sit with the cap just sitting on it, not actually closed, for about 30 minutes or so. It should bleed itself off a little more once you get to that point. Top off again and go ahead and start it with the heater on so it can cycle through everything.
If you have any doubts at all about your thermostat, go ahead and change it, put a failsafe in for piece of mind. Now would also be a good time to add an aftermarket temp gauge while you've got the dash gauge sensor out of the head.
Driving it with it not bled off all the way could cause problems, depending on how low it is, you will have large air pockets and hot spots. Not good.
If you run into any problems post back and we'll see if we can get ya fixed up. I will say though, putting an aftermarket temp gauge in mine was one of the wisest things I've done with this car. Dash gauge is a joke, as you can tell.
