scottso |
04-04-2007 09:55 AM |
Convertible Top Knowledge Needed
As with many - my rear window has separated at the bottom - inside and out. I purchased epoxy - the inside looks pretty easy. The outside flap at the bottom is coming up maybe 1/4" short of being fully seated on the window. I suspect it has been loose for a while and shrunk a little. Does anyone know if I can loosen the steel clamp inside the car (under the window) in the back to gain a teeny bit more material? Or am I asking for trouble by releasing that tension?
