02 Trans Am no headlights after car wash
Old 12-04-2013, 11:00 AM
94arcticwhiteM6's Avatar
Yesterday morning my headlights worked just fine. That afternoon I washed the car, now they will not come on. They do not pop up and the headlights themselves do not light up. Going to check a few things today but looking for any other suggestions.
94arcticwhiteM6 is offline
Old 12-04-2013, 09:43 PM
Prominent Member
GaryDoug's Avatar
Location: Born on the Florida West Coast, now where can I retire?
Re: 02 Trans Am no headlights after car wash
There's really only two things to go wrong in this case other than wires and splices: the light switch itself and a fusible link among those next to the underhood fuse/relay boxes.
The light switch does have an internal circuit breaker that will reset after a period of time. If nothing else works, try unplugging all 4 headlamps and waiting an hour to see if the headlamp door motors work then. If it does, that would indicate a short in the area of the headlamps.
GaryDoug is offline
Old 12-19-2013, 05:35 PM
The motors work when you unplug all 4 headlights. I'm figuring there is a short somewhere. I get continuity to ground from the ground pin and hot pin of the headlight connectors. The breaker does seem to do a reset and I will get 12v on all of the hot pins, but plug in a headlight and it all goes away.
Old 12-19-2013, 05:51 PM
Prominent Member
GaryDoug's Avatar
Try unplugging all 4 again, then after confirming that the motors work, plug them in again one at a time. Check the motors after each one is plugged in. You can either narrow it down to a signal lamp or verify that it doesn't matter which one(s) are unplugged. If it is just one, there is a short, and yes the lamps themselves can short internally. If it doesn't matter which one(s) are unplugged, the circuit connection is weak somewhere, perhaps at the fusible link or switch.
GaryDoug is offline
CaRParts102
12-06-2014 08:45 AM
12-04-2014 11:56 AM
Lederman1976
11-30-2014 05:21 AM
siguy
11-27-2014 10:07 AM
USAirman93
11-24-2014 03:37 PM
Quick Reply: 02 Trans Am no headlights after car wash
