Cars lights pulsate and dim with idle.
My 96 Camaro's headlights and dome light and every other light I guess dims and brightens with the idle of the motor. I noticed the ground wiring on the ignition coil is pretty chewed up and shanty looking. What are these wires for, where do they go? Looks like a braided ground strap and 2 wires hooked into one ring and they're all bolted to the ignition module.
Re: Cars lights pulsate and dim with idle.
The grounds are just that - they go from the coil stud to the driver side frame rail. How is your voltage reading?
Truth is though the light circuits aren't grounded through the engine block so those grounds won't make a difference. |
Same symptoms happened on my brother's 99 3.8 Camaro V6. It was the alternator. Have it checked out(regulator issues).
You can have it tested free, at most auto parts stores.
Nice, thanks guys, I swapped out the alternator and it's perfect now.
Originally Posted by RamAir95TA
(Post 6897644)
Not sure what you mean by "ratchet", but if you are talking about it not disengaging after starting, it could be the starter going out. You can have it bench tested for free at a lot of the parts stores to be sure. If you battery or alternator we not working correctly, it could affect your starter, so see if it still does it after your alternator replacement. I would clean and replace all the grounds that need to it.
