Cam Questions
Hello all,
I have a friend that has a 71 Firebird with a 350 Pontiac Block currently has the stock cam. He is thinking about getting an Edelbrock Performer RPM Cam with Spec: Duration @ .050" INT/EXH .231/.240 Lift INT/EXH .470/.470 He would also change out his Manifold to an Edelbrock Performer RPM 1,500-6,500 PRM; keeping the Stock heads does anyone know how much he is looking to gain from this cam? I think the Stock Cam spec is: .376 Lift INT and .412 EXH He is looking to get more of an aggressive sound and of Course better performance and reliability wise. Any info would be great. Thanks |
that cam isnt going to give him alot more than stock. .470 .470 lift isnt alot,and probably wont sound radical at all. take a look at the Comp Cams website at http://www.compcams.com/Technical/DynoSheets/
i would prob. go w/ the XE284. it has decent lift,and still produces enough vacuum for power brakes. check it out |
thats Cam shows that it is for a Chevrolet 350 Small Block he has a Ponitac 350 Block. will that still work?
TTT
