A/C troubles
The a/c in my daily driver has decided to die. The car in question isnt my f-body and wishes to remain unidentified :D . I hooked a gauge up to the low pressure port and monitored the system. Basically the pressure would rise to 45 psi and the compressor would kick in. About one second later the pressure would drop to 20 psi and the compressor would turn off. All it does is basically cycle over and over. Any ideas what would cause this?
Re: A/C troubles
You are most likely low on refigerant.
