a/c clutch inop.
Can anyone tell me how to jump the low pressure switch? This is a three wire switch that i am not familiar with. My wife thanks you too!
Re: a/c clutch inop.
the switch is a combination of low and high pressure. This means that you can't jump it since the computer will not see the correct range of resistance. The only way to force the clutch on is with the TECH2 or similar tool. Are you getting 12 volts at the compressor? If you are then the switch is not the problem.
