Air Pump
Air Pump
Can ANYONE tell me if I take out the PCM fuse for a few minutes and then do an OBD2 emissions test it will nt notice the A.I.R. system running incorrectly?? I have to get the car inspected but I've lost my vacuum solenoid and bleed vlve and the ca is still throwing an SES. I thought that just plugging the air pump in would solve it but then I cant find these parts anywhere...so now I'm tring to figure out quick way around this problem. Thank you for ALL the help!!
Re: Air Pump
you need to fix it so it works or have the AIR code/test programmed out
oh, you need to drive the car for a while after clearing codes(needs to run all the tests), or you will stll fail the test
stockssn2o
May 25, 2015 08:54 AM
Magenta_Hearts
Mar 22, 2015 03:36 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
