Air Conditioner Woes
I have a 2000 Camaro SS. The problem with my air conditioner is that i can recharge it and within a day or 2 it blows hot again. I am guessing the compressor is fine and there is probably a leak somewhere. I was reading a thread on ls1tech about changing the orifice tube. Do you think that could have anything to do with it?. or is it a leak somewhere? If it is a leak where are common leak areas?
Re: Air Conditioner Woes
I wanted to say hello from Houston Texas, I have a red with black top Camaro Z 28 1995 model, she has 25,020 miles original on odometer, my father and I bought her new in 1994 November for mothers retirement present... it looks is like new because she sits all the time.
well I decided 2 weeks ago to put the beast as a sunday driver for good now, so I got a battery after a 3 year sit and no run, got new fresh fuel, checked all the fluids changing the oil and adding new antifreeze and she started right up... but she was running bad I guess injectors where a little dirty, I added fuel treatment STP cleaner and after about 3 10 minutes starts she started running much better, half tank of fuel later she runs tops again, good enough to pass inspection.
Problem: the AC was low on freon so I added some after start up, I filled system and no dice hot air only... then I read a tread here that said that sometimes you have to disconnect battery to clear the computer from having message of Freon being too low... I did it and my god that was it!!!! immediate cold air :-) . now I cat even find the thread to tell the guy thanks a lot for great advice....
any how thank you all for advice
Latronaxe
05-14-2015 01:23 PM
squarehead
01-15-2015 07:02 PM
95chwagon
01-13-2015 09:19 PM
