98 speedo
Can i use a 98 speedo in my 94 z28 with a 94 dash or will i need to swap everything ?
Re: 98 speedo
93-97 only in an LT1 car
Re: 98 speedo
So why does the 97 have the same speedo as a 98+ cars ?
Re: 98 speedo
I believe this is how it is, according to the service manuals:
97 Firebird is the same connector as 98 F-bodies 97 Camaro and earlier are different from 98 |
Re: 98 speedo
so basically i have to either find a 97 z28 cluster or a 98+ firebird cluster ? and is this bc it is obdII or is it just bc
Re: 98 speedo
Nothing from 98 up will work in your 94 as far as I know (no expert here). No Firebird cluster will work either. I think a 94-97 Camaro will work like was stated before. Not sure about 93. I am basing al this this on what I see in the service manuals that shows the 94 and 96 Camaro having a different connector from any 98, and different from any year Firebird. I have no experience with these parts.
Re: 98 speedo
Not sure why this is in "Parts For Sale".
Moving. |
Re: 98 speedo
oh i get it so i will have to swap it with a 97 cluster ? will it fit in my 94 dash ?
Re: 98 speedo
You can put a 97 dash cluster in a 93 through 96. But you will need to change out the dash and center
consol, and repin the cluster conector to the 97 style. Even though the cluster shape is the same for 97 and up the electronics are different for the various guages in the 98 and up. |
Re: 98 speedo
i may have to do it that way what all do i need to re pin ?
Re: 98 speedo
You need the connector for the 98 cluster, the plastic connector that came from the 98 . I believe the 94 and 98 connectors are shaped differently so the 94 wont fit in the 98 cluster.My car was done when I bought it, so I dont know which wires go where. You would need the wirring diagrams for both cars to do the repin. But it is doable.
Re: 98 speedo
thankas but if i do it i would rather just put a 97 dash and cluster instead less of a headache this way right ?
Re: 98 speedo
Originally Posted by blac94Z
(Post 6972731)
