3 quick questions
1. Will the intake boot from a vented opti 95 work on my 93? (mine is ripped to shiz)
2. What do i need to make a LS1 catback work on my 93? 3. What size are the threads on the M6 stock shifter? |
Re: 3 quick questions
I can help ya with #2, but thats it. You can buy an S pipe from somewhere like Summit, or you can buy the SLP Loudmouth S pipe from SLP. I believe they are the same thing.
I can help with #1. You will just have to plug the hole in the elbow and it should work fine. I think its the filter side that is longer to meet the elbow in the 93's since they have no MAF.
threads are metric...not quite sure how they are measured..
but they are listed as 16mm-1.50 that's probably 16mm dia, with 1.50 threads per mm |
