10 sec cars and there problems
When you get a below the 11's mark what problems do you run into? I have a car that has alot of tq/hp and it seems to be having problems everyday. I kno the 10 bolt is a problem but everyone knows that. What is it that you have had to do to keep your car alive, rather it be engine related or chassis?
kindda a vague question....
i guess replace everything that is going bad with something better... trans with something stronger rear end with something unbreakable full cage to keep from twisting simplify and beef up all the electronics |
Im hearing things bad about the stock tourque arm, something bout it popping the floor board?? whats up with that? Which subframes would be the best for dragging and handlein and would they wor with a 12 bolt and aftermarket torque arm? Im jus trying to see what i need to order before this engine kills my car.
well i've never heard of the TA messing up the floorboards...the problem i think is that it attaches to the talilshaft of the trans...which could cause problems.
something like the BMR trak pack fixes that, combine that with thier boxed sfc and you should be good. and it the 12bt is designed to fit the stock TA ...it will fit hte trak pak too. |
the bigest problem with a 10 sec car is traction on street tires.
The trans is the biggest problem I've seen by far. You have to do alot to keep it going strong. Ofcourse I'm excluding the rear end and all that stock b/s. If the motor is built well, it's going to survive for quite awile on the street and the track. Huge shots of N20 used alot at the track takes it's toll as well or excessive boost. Other than that and what's been mentioned above I really cant think of anything else. Just keep the car well maintained and stay on top of things and you should be good. Also, clutches seem to go alot sooner.
Is everyone still running stock fuel pumps? What type shocks? Tranny mounts? Im gonna try to stay away from a roll cage, anyone have problems with there tach keeping up with the car? Im jus trying to see what my car is gonna need to keep it in the perfect running car. When i buy replacement parts i want the best, good replys guys.
Most people have switched to a better intake pump by the time they hit 10's. Shocks would be based on personal preference, but something like a QA1 shock would work. The poly tranny mounts would be my guess. As far as the roll cage goes, you'll probably be kicked out if you run faster than 11.50 without one. And I've never seen a stock tach that was on the money, besides you will probably want one with a shift light because there isn't much time to read a tach at that level. :)
Originally posted by my94blackz Is everyone still running stock fuel pumps? What type shocks? Tranny mounts? Im gonna try to stay away from a roll cage, anyone have problems with there tach keeping up with the car? Im jus trying to see what my car is gonna need to keep it in the perfect running car. When i buy replacement parts i want the best, good replys guys. |
We're supposed to make sense on this board? :irk:
:lol: :lol: :lol: |
Originally posted by 97WS6SCharged We're supposed to make sense on this board? :irk: :lol: :lol: :lol: Just thought I would clear it up for the newbies or something before they were asking what was up with my post. A few drinks makes and I just kinna answere in the order asked. Don't really care about making sence. :D |
biggest problem with a 10 sec car is that you then want a nine second car. LOL
Well when my spray comes in it will be to decide if i want 200 or 250 :D anyways my engine should be a good 450 flywheel hp and alot more torque. Im jus been having a lot of problems after the install, i was just wondering who else was having problems with there quick rides. My car will stay full trim and wont have anything took away fom the class side of the car. I knew the rear end was weak just wanted to know what everone else was having problems with.
If the car is put together properly, you shouldnt' really have any problems
450fwhp is not all that much. even with over 2x that my car was driven for 8 months with out incident (never stranded, etc). Hell, I never actually broke anything. also never ran it at the track at that time, although i did beat the hell out of it on the street |
