Won't Turn Over or Start
91 Z/28 350sbc tpi t5 Manual trans
When I turn the key all my gauges and lights turn on but when push the clutch in it wont start, it wont even attempt to already had starter tested and it was fine and changed the reverse/neutral switch on the transmission. ANY SUGGESTION? Thanks :no::no::no: |
Re: Won't Turn Over or Start
OK figured out I fried what my Haynes books says is a fusible link from what I can tell from the wiring diagrams
That wasn't it, in need of help!!! Ok my Vats system has been bypassed security light turns on then off like it is supposed to. Anti- theft relay is fried ordered a new one but the connector from the wires is fried and i can't find them anywhere, does anyone know here i can buy the wire connectors/fusible links.
Did you try an ebay search?
Have not yet because I'm trying to trouble shoot everything first before i go buying a lot of stuff
| All times are GMT -5. The time now is 12:37 AM. |
