fuel tank assembly line
hey can anybody provide me with a diagram of the fuel tank assembly i have a gas leak thats pouring out of the fuel tank vent valve after driving for 20 minutes. i would like to know where the lines exactly go because the mechanic that worked on my fuel pump isnt cooperating with me in this leak. so id like to take the matters into my own hands. thank u eveybody
There are four lines that come out of the fuel tank.
Two go to the fuel rail (feed and return).
One is the fuel tank vent valve (with the white valve you mention).
The last one goes to the charcoal canister in the driver side quarter panel.
for sure cool hey how do i know what line for the fuel tank vent valve goe because after a certain of time of driving the pressure builts up in the tank and then fuel will leak thru the vent valve (white valve)and like u said and fred said that if fuel comes thru there the line is in the wrong place
Its my GUESS that you may have the hoses connected incorrectly. There's no way anyone can say that with certainty.
Shoebox has a crude drawing of the lines from the shop manual, but it doesn't show it very clearly:
http://shbox.com/1/evap_system.jpg
I got it guys i fixed the issue one of my fuel hoses thats connects to a piece that has a bracket on the throttle on the passenger side of the engine was out. i put a small clamp on it so it wouldnt fall off, by that hose being out my fuel tank was building so much pressure and gas was leaking thru the fuel tank vent valve.
THANK U TO EVERYBODY who partcipated in Mike's car issue
i didnt mean for u to get lost Fred i mean the evap purge solenoid there is a bracket on it, one of the lines that runs along to the fuel lines was out of the solenoid causing a lot of pressure to build in the tank. oops im sorry i dont know why i put throttle im sorry dude
10-31-2016 11:09 AM
APS95Z28
09-05-2002 10:21 AM
guionM
9
08-29-2002 01:48 PM
guionM
18
07-11-2002 01:45 AM
