CamaroZ28.Com Message Board
-   Fuel and Ignition (https://www.camaroz28.com/forums/fuel-ignition-74/)
-   -   rev limiter (https://www.camaroz28.com/forums/fuel-ignition-74/rev-limiter-882229/)
cristian1311 Apr 22, 2015 06:21 PM
rev limiter
hey guys i have a 93 z28 383 stroker, I've added a few bolt ons and exhaust. i was wondering what does a rev limiter do? oh and what are the pros and cons of putting one in? thank you
Injuneer Apr 22, 2015 07:46 PM
Re: rev limiter
You should already have a rev limiter.
The stock rev limiter is programmed into your computer (ECM). I prevents the engine from being revved beyond the desgn redline of the engine. It does this by shutting off the fuel injectors when RPM reaches the programmed value. The stock setting is a bit over 5,800 RPM, with slight variations depending which gear the trans is in.
If your engine has been modified and a new tune programmed for the modifications, the RPM may have been altered in the chip burned for the new tune.
Benefit - prevents,your engine from being revved to the point where the engine can be damaged.... e.g. bent pushrods, floating the valves, etc.
cristian1311 Apr 22, 2015 10:20 PM
Re: rev limiter
Very helpful. Thank you!
