MSD cap & rotor..what else to get while im down there?
going on a trip on the 6th and getting alot of things replaced before i go even if not completly needed.
94 Z28
Things replacing:
- Transmission & T-Converter from Performabuilt (lev 2)..needs it, only has 1st and second :P
- Oil change (0w-30 signature series amsoil) - thats whats in it already
- fuel filter
- PCV valve
- DENSO Part # 2344012 O2s (exact same thing as AcDelcos
- 4 tire alignment
- serp. belt
- Changed all 4 rotors and brakes
- and last but not lease cap and rotor.
Replacing with http://cgi.ebay.com/ebaymotors/92-94...spagenameZWDVW - 92-94 LT1 Camaro MSD Optispark Distributor Cap Rotor 154.60
The cap and rotor is going to be the most time consuming sence a shop is just installing the trans.
Sence im down there installing the never been changed cap&rotor..what else should i change?
It has a new water pump all ready
semi new MSD 8.5 wires & blaster coil w/ bosch Platinum Ir Fusions
Anything else?
94 Z28
Things replacing:
- fuel filter
- PCV valve
)- 4 tire alignment
- serp. belt
Anything else?
Formula Steve
Sep 19, 2023 08:31 AM
