Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
A good aftermarket Opti?
Old 03-20-2018, 01:23 PM
Rod Bender's Avatar
There has been a lot out about how bad aftermarket optis have been. And GM optis seem to be the way to go. However, I was at the saccitycorvette.com site that sells the AIP opti which has the Mitsubisi module and claims output to 8000 rpm and is used in some racing event. Has anyone had experience with this unit?
Rod Bender is offline
Old 03-20-2018, 03:08 PM
DrewHMS97SS's Avatar
Re: A good aftermarket Opti?
The rebuilt AC Delco is what most recommend. I have a Dynaspark from before the company changed hands and quality dropped, with no issues.
It seems for something outside AC Delco, some have looked at Ventilated Optispark Distributor | Petris Enterprises
I have not heard of Saccity. Be careful about the module, as they state they use their own Mitsubishi spec module, not a Mitsubishi module specifically. They do provide a 2 year warranty, so as long as you are okay with the possibility of extra work, there is a significant cost difference and a 2 year warranty.
Personally, if it's too good to be true, it probably is.
DrewHMS97SS is offline
Old 03-20-2018, 09:40 PM
Sac City Corvette resells the AIP (All Ignition Products) Opti for $60 more than AIP sells it for. Haven't heard anything about AIP for at least 5 years. Before that, their Opti was recognized as a certified, complete POS.
Injuneer is online now
Old 04-06-2018, 03:02 PM
Rod Bender's Avatar
Thanks for the reply, Fred. Now, how does jet.com advertise a "AC Delco, D8301 by AC Delco" for $151.78 ? Bill
Old 04-06-2018, 03:33 PM
I wouldn't trust the site. Again, too good to be true, it probably is.
Old 04-06-2018, 03:43 PM
Rod Bender's Avatar
I just looked at Rockauto and they now have a GM Delphi Pn :1938351 for $224 with core
and a Pn: 19212399 for $307. incl harness with core. Some place I read where not all harness adapters were the same.
Old 04-06-2018, 09:03 PM
Rod Bender's Avatar
I must be late. I just checked Rock Auto and was informed the Delphi Opti is not available.
Old 04-05-2019, 02:59 PM
Rod Bender's Avatar
I am not sure I need an opti. It is not oil covered. Maybe I need to check the computer.
Old 04-05-2019, 10:29 PM
What specific problems are you experiencing?
Old 04-06-2019, 11:06 AM
Rod Bender's Avatar
Well, if I remember it just seemed to have a misfire.
Old 04-06-2019, 11:14 AM
Rod Bender's Avatar
The car has recent plugs and plug wires.
Old 04-06-2019, 11:35 AM
Not a lot to go on....
Misfiring under what conditions? Have you checked the fuel pressure? Have you scanned for codes? Have you had the coil and ICM tested? Did you inspect the Opti plug wire terminals for corrosion when you changed the wires?
Old 04-09-2019, 09:30 PM
Because it is a cap and rotor kit-not a complete optispark.
shoebox is offline
Old 04-09-2019, 10:13 PM
Kind of odd.... there's a one year gap between the posts...... 4/6/2018 ——> 4/5/2019.
LearJet
11-04-2009 10:12 AM
30th6
11-14-2007 04:42 PM
clcam97
06-17-2007 11:49 PM
Black95Form
08-05-2004 10:46 AM
1FstFormulaV8
03-15-2004 07:42 PM
Quick Reply: A good aftermarket Opti?
