Yes or No to a 4.5 supercharger
I have 100k, babyed my car , lots of TLC . Runs awesome. New opti,WP. Loudmouth. My best et was a 13.6 w/ dr's.
So yes or no? I just recieved a huge check and im itching to go shopping.
N/A!!!
just kidding. If you want forced induction, I would venture into the turbo realm. My friend has a T4 in an MR2 and it hauls A$$, and that's just a 4 banger!
trust me, he can whip most Z28's if they are relatively close to stock.
A powerdyne 4.5 psi is fine. Boost that low isn't gonna destroy your motor. Just use a boost timing control.
Everyone says get ATI or Vortech because those are the best in hi-hp applications and are upgradable to provide tons of boost.
My car made 340rwhp/372rwtq with a powerdyne 4.5psi blower and Hooker shorties. I later sold the kit to friend of mine and he made 326rwhp on a completely stock '95 Z28 AUTO w/ 120K on it.
Powerdynes are very easy to install- no oil lines or anything.
Your looking at a 75rwhp increase using this blower.
Don't waste your time with a 4.5 powedyne......Boost is addictive and you'll be looking to dump it and upgade to a Pro Charger in no time
When you start getting into real boost (over 7-8 #"s) you start to need other stuff to support it (fuel system, gauges, exhaust, tuning and then drivetrain upgrades are in order over time.
Someone mentioned 340 HP w/ a 4.5 powerdyne, if that was all I wanted I'd sell my LT-1 Z and get a LS-1 and put a cam in it and do some PCM tuning.
Marc
Marc
I personally think there is no point in adding a s/c or turbo that will be running below 10psi. It defeats the perpose of having forced induction. Plus it's a lot of money for only 4.5 psi. You should built up the engine for f/i. That's my $.02
I think I made full boost at like 3600-4000 rpm. It was *110 degrees the day we dynoed it and my temp needle was above *210 when we put it on the dyno. I later upgraded to the 6lb pulley and felt a big SOTP difference.
You can't beat the Powerdyne for low boost/stock short block'd setups.
I bought my BD-11 4.5psi kit on this message board for $1400 shipped.
