What's missing? Vortech V-9
I might buy this vortech supercharger. Here are the pictures the guy sent me
Here is a list of all the things that vortech says is included with the kit.
V-9 G-Trim supercharger with air assist, SQ gears and 8-rib 2.95" pulley to produce approx. 8-9 psi.
NHRA legal aftermarket steel harmonic damper replaces the factory iron unit.
8-rib aluminum crank pulley to drive the supercharger.
Air/Water aftercooler assembly with pump, wiring, surge tank, reservoir and front mount heat exchanger for effective street operation.
T-Rex® fuel pump assembly with wiring harness.
Eight 38 lb./hr. replacement fuel injectors.
OEM style cast aluminum supercharger mounting bracket.
Automatic supercharger belt tensioner.
Compressor bypass valve
Cast aluminum discharge and air inlet ducting.
Oil drain, oil feed, air discharge and air intake assemblies.
Handheld ECM re-programmer
tool for modifying oil pan for supercharger drain fitting
I'm not seeing a handheld programmer, fuel pump, injectors or the crank pulley. Am I just blind? What else isn't in there? Thanks for the help.
tommalcolm
Sep 11, 2015 03:39 PM
