What size springs
Now for the wastegate, the spring has 2 options:
1. It should be close to what boost level you want and then you use a boost control to increase it a little more. Example: If you want to run 20psi, you can probably run a 15psi spring and then use the boost controller to get you to 20psi.
2. Run a spring equal to the boost you want to run..
ChrisFrez
Mar 29, 2015 09:43 PM
