What is a great head gasket for boost?????
I blew head gaskets today on 11psi for some odd reason. I didnt think it was possible on such a low boost level. I have felpro 1074's on there right now, ca any one think of a better gasket to use or just stick with them again?
I went with Cometics.
I was thinking of those, but i have heard you have to have something done to the head surface? Is that true?
They just need a smooth finish. I think most machine shops go plenty smooth on heads for cars w/o MLS gaskets anyway.
This topic has been covered numerous times, and just recently, as I had the same dilema. I dont blame the gasket at all looking back. I had a few issues which could have caused it.
To summarize: I dont think I had the arp bolts torqued down enough as they spec higher than factory torque; My meth inj. line burst in the middle of a WOT pull and the wideband hit 12:1 and I let out but unfortunately it was too late; The previous 2 together could have caused detonation with the high intake temps and forced the gasket out. In the end, I chose to do it again with 1074's as alot of guys are using them with more boost than I have without issue. As someone stated in my thread, its all in the tune. Use the head gasket as a fuse, its better to replace the gaskets than pistons,rods, etc. Just remembered I was also running 26-7* timing, which didnt seem to be an issue and that car ran like a raped ape, but when combined with my other issues, was probably a recipe for disaster. Chalk it up to sh!t happens and look into your tune. |
Originally Posted by blown94
(Post 6380798)
I will go over the tune and look for something that may need lowered for durability i guess, but i was thinking of just parting the car out due to time and money constraints. college sucks! plus im kinda sick of working on it. |
You know, it also never occurred to me, but i was jst re-reading the post, and you dont state what compression ratio yer running? What dish, what head chamber size, and how much deck is left at TDC? If you're CR is above 9.5:1 thats part of the problem.
I hear ya on being tired of working on an lt1 f-body. It takes alot of patience, alot of time, and a lift is a great help. Without those, I wouldnt have one myself, as its a pain to do most anything to it. |
(Post 6386497)
Well, yer CR is about right for 10 psi from what ive been told. Any lower than 9:1 will hurt off boost perf. in low (<15 psi) applications. On the other hand, you dont want to go any higher thats for sure. Ive got main studs in my 2 bolt and regular ARP bolts in the heads. I noticed ARP wants like 77 ft/lb with arp lube or something like that, check because its different with oil or arp lube, but I know for certain its more than stock, or what most people use (65 ft/lb). Make sure your surfaces are clean as can be, and make sure you torque in the right seq. and double pass the last pass to be sure. Other than that, keep the timing moderate and IAT's down. If you aint runnin an intercooler and yer in higher temp regions, you should at least have a meth kit to help control intake temps and reduce the risk of detonation. And I dont think this needs to be said, but, always run good fuel no less than 91. Try mixing some higher octane fuel if you cant get 93.
(Post 6387966)
oh well it happens i guess. the highest intake temps i saw i was in boost for a while climbing up hill was 139 degrees on a 95 degree day, i do not know if that is too hot or not but i don't have an intercooler. |
thats not bad considering 95* day. I too failed to torque the bolts to arp suggested specs, now whether that factored into the issue who knows, but I do know for a fact I did not use arp's specs the first time around. This time I did, and havent had an issue yet with the head gaskets again and yesterday I saw 12 psi @ 6k rpm and it was about 90*+.
One thing to consider: ive heard the intake air temp does not update very quickly, so you're raeding may not be accurate. I remember reading that it only updates like twice a minute or something ridiculous, so I wouldnt count on that. You need a realtime IAT sensor from what ive read. |
The computer polls the IAT fairly often. Make sure you are using an open style IAT and not a closed. Closed looks like a coolant sensor.
Well I have watched the IAT's go up when I'm in boost and you can see it change probably every two seconds so I am fairly sure it is accurate.
jsetzer- I have an IAT out of a GMC cyclone and the only difference to the stock one is it is metal. |
Thats the one I run -
Originally Posted by jsetzer
(Post 6390480)
