Vortech head bolts stripped from the factory...
Old May 4, 2009 | 04:33 AM
ss#1230's Avatar
anyone else had this?
i had to re-clock the unit since it wasnt in the right position to begin with. i loosened the bolts that hold the little clamp thingies that secure the volute to the head, and once i clocked it to where it should be, 3 out of the 6 bolt/screws wouldnt tighten down. so, i pulled one out, and the bolt threads had aluminum stuck in them.
i had emailed vortech a long time ago asking about some torque specs. the guys answer was "as tight as you can get it without stripping it". i cant believe this crap. now im going to have to drill em out and tap em for bigger bolts.
Old May 4, 2009 | 08:45 AM
ak95ta's Avatar
I had stripped one of mine out and found a longer screw and it worked fine. A 1/4 20 bolt tightened into aluminum has a torque spec of 10 ft lbs +/- 2. 10 ft lbs aint much so its easy to over torque and strip it out.
Old May 4, 2009 | 11:32 AM
ss#1230's Avatar
thanks for the specs.
i'll try a longer bolt.
Jeremy
maybe2fast
Mar 16, 2015 09:45 AM
95chwagon
Feb 28, 2015 12:02 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
