turbo technology kit
Thinking about getting turbo. Any good/bad words about http://turbotechnologyinc.com/ls1.htm kit How it compares to STS?
I have A4 Z, 2002
I have A4 Z, 2002
Re: turbo technology kit
I use to live up in Seattle Washington and Turbo Technology which is in Tacoma, did some custom tuning on my car. They were very knowledgable and did a great job on my car. I have heard of a few LS-1 guys who have run their kit and like it. If i remember right they are running the 76 turbo. Dont go with the 60-1, it sucks! I would say go with PTK if you are gonna spend the money. Visit their site www.proturbokits.com. Their LS-1 kit is easily the best out there on the market. If it were between the turbo technology kit and an STS i would opt for the turbo tech w/ 76mm turbo! Hopefully you will get some more advice from someone that actually owns an LS-1 with a kit installed.
FWIW, I have been very happy with my TTi Stage X kit (Y-Body).
The rear mount STS style setup is totally different.
The real questions are how fast do you want to go, how much money are you willing to spend, and what if any features (air conditions for example) are you willing to sacrifice.
Good Luck,
Mark
Good Luck,
Mark
Sorry, I should give this info at the beginning.
I want to go as fast as I can afford within my budget (7k max, installation included). This is my daily (and only one) car so I want to keep it super reliable for 2-3 years and one reason I prefer turbo vs charger is that I will not use it 99% of the time and as I understand in this condition turbo is safer. I do not want to relocate AC or change any engine internals.
You're probably better off with a supercharger. If your car must be reliable, you should know that turbo's produce alot more underhood head, fry wires and hoses, blow exhaust gaskets regularly, etc. . . The Vortech and ATI kits will have better overall fitment han any turbo because they are mass produced to be installed by the ordinary guy.
Mike
Mike
The heat issues you describe are common with the top mount turbo kits. The TTi setup, at least with the C5 kit, is hung low. I haven't had *any* heat issues or anything else for that matter.
Blowers and reliability are generally not used in the same sentence.
Mark
Mark
Originally Posted by engineermike
How could they be less reliable than turbo's???
Mark
The idlers, tensioners, and bearings in the Vortech kit are supplied directly by Ford and they are the OEM parts on some production car. I guess if you run it 150,000 miles, it may have a problem.
I, too, have had both, and waaaay more problems with the turbo setup.
Mike
Mike
Mike
Mike
Sorry, I was saying the 60-1 turbo sucked due to its ability and size. I was under the impression you were looking for more power. If you are only looking at about 450 then it should support that no problem. Ask the guys over at turbo technology if you can ever upgrade to the 76 on your specific kit by changing down pipes etc. You want to keep your options open on something like this.
Mike
Mike
