CamaroZ28.Com Message Board
-   Forced Induction (https://www.camaroz28.com/forums/forced-induction-10/)
-   -   Turbo headers?? (https://www.camaroz28.com/forums/forced-induction-10/turbo-headers-328994/)
RealQuick Dec 30, 2004 02:50 PM
Turbo headers??
If I decide to make my own, I figure it may be a good idea to modify existing headers.
Here is my question, is it possible to modify any small block chevy headers, or do they need to be LTx specific? If I can find a header that fits good (whether flipped up side down or not, and just weld ona vband flange) then thats what I want to do.
kcshaner Dec 30, 2004 03:13 PM
Re: Turbo headers??
The headers that fit my application are from a 96 Chevy 305 truck flipped around.
SMOKNZ Dec 30, 2004 07:08 PM
Re: Turbo headers??
I'd like to see pics. I tried to do that but it got to the point that they had to be so extensively modified that it was easier to build from scratch. Plus the flanges on those small block headers are only 1/4". I would think they would warp pretty easily. The room in the Fbody engine compartment as you know is pretty small, and then you have to deal with the accessory bracket on the passenger side. There is no flipped shorty thats going to clear that. I did see a pic of a car with block huggers flipped upside downwith the turbo flanges welded right on, but it was in a truck and had lots of hood clearance.
Bill
96TurboTA Dec 30, 2004 08:03 PM
Re: Turbo headers??
You could prolly weld up a driver's side header, and pipe the existing passenger side down under the AC compressor and over to the driver's side. I think Jordan did it that way his first time. Here's a link to his t76 system http://fastblackcar.com/camaro/turbo.../turborouting/
SMOKNZ Dec 31, 2004 08:23 AM
Re: Turbo headers??
I was talking a twin setup, but I suppose a single might be do-able like that. You would have to have the passenger side go back behind the engine and up to the other side because with the pass side forward swept, it will run into the accessory bracket. A single cat drivers side manifold on the pass side might work, as it goes pretty much straight down at what would be between #2 and #4 cylinders (if it was on the pass side). Then run a flipped shorty on the drivers side.
97WS6SCharged Dec 31, 2004 09:57 AM
Re: Turbo headers??
It would be a tight fit trying to fit a cross over and a down pipe on one side of the engine, especially in a 4th gen engine bay. I think it would be easier to run the cross over around the front of the engine along the front of the K member. A tubular unit would definately help. :)
96TurboTA Dec 31, 2004 10:51 AM
Re: Turbo headers??
something like this? http://fastblackcar.com/camaro/turbo...g/DSCF0180.JPG
SMOKNZ Dec 31, 2004 11:36 AM
Re: Turbo headers??
I think what I was trying to say was if you ran the manifold on the pass side you would be able to run it forward, the exit of the manifold would be toward the front of the car that way. I'm not sure if it would clear the motor mount though.
sleeperz28 Dec 31, 2004 12:39 PM
Re: Turbo headers??
my buddy flipped the slp headers to make his kit for his single T88
SMOKNZ Dec 31, 2004 05:34 PM
Re: Turbo headers??
Single cat or dual cat headers?
RealQuick Jan 1, 2005 01:28 PM
Re: Turbo headers??
Thanks for the responses guys. my main concern was did they have to be LT1 headers, or will and SBC headers have the right spacing and bolt pattern?
SMOKNZ Jan 1, 2005 01:59 PM
Re: Turbo headers??
Yes they will bolt up, May have to do some minor clearancing, but nothing major at all.
96TurboTA Jan 1, 2005 02:07 PM
Re: Turbo headers??
How did he clear everything on the passenger side? Did your buddy take pics of his setup?
will62085 Jan 1, 2005 02:50 PM
Re: Turbo headers??
they will bolt up, but lt1 heads are D shaped ports...while older sbc heads have oval ports...i dont know when the change was, or which headers will work...i was thinking about using lt1 corvette block huggers
engineermike Jan 2, 2005 04:44 PM
Re: Turbo headers??
Here are pic's of my custom single set-up. It's for a PT-76 GT-S. The passenger side header is missing, but it is a regular SLP shorty in the standard orientation. The driver's side header started out life as an SLP shorty, but I mainly just used the flanges and maybe 2" of pipe.
www.2weird.com/mike/pic1 mod.jpg
www.2weird.com/mike/pic5 mod.jpg
