CamaroZ28.Com Message Board
-   Forced Induction (https://www.camaroz28.com/forums/forced-induction-10/)
-   -   Turbo gaskets? (https://www.camaroz28.com/forums/forced-induction-10/turbo-gaskets-89892/)
BigDaddy Mar 6, 2003 01:30 AM
Turbo gaskets?
I've been looking for a gasket for the turbine outlet of my 60-1HiFi turbo, and can't find anyone that sells them. Do you think I can make one out of copper? I've got some lying around.
89ProchargedROC Mar 6, 2003 02:14 AM
do you mean where your downpipe attaches?
If so...no need for a gasket. Ultra Red silicone is your friend
BigDaddy Mar 6, 2003 09:06 AM
yes, that's exactly what I meant. Thanks for the info.
89ProchargedROC Mar 6, 2003 11:19 AM
No problem....the ultra red or copper works good. Just put on enough so that when you tighten down the bolts it oozes out a little. Then start it up, you'll have some leaks at first but usually after running for a bit it'll harden up from the carbon and you'll be good :)
