Turbo Fabrication Progress (pics included)
Old Mar 21, 2007 | 03:30 PM
  #46
RealQuick's Avatar
Originally Posted by will62085
haha, its easy to do, if your serious i can help ya through it. the system rocks.
You ever get past that 5000rpm issue you had?
Old Mar 21, 2007 | 03:31 PM
  #47
LT1-TA's Avatar
I really hate the low resolution... but i do want to do it.... and since i already have a OBDII car.... I have the timing cover and sensors i need to make it happen.
But how much would i spend from beginning to end doing it? I REALLLLLY dont want to use this OBDI and tunercats.... SD would be sooo much nicer..
Just ur one of the VERY FEW that have got it done on a lt1...
Old Mar 21, 2007 | 03:57 PM
  #48
will62085's Avatar
The MSII..has lot better resolution than MSI, and you can play with the values on the tables to add resolution where you need it, ie, cruising and stop and go, idle, and less resolution up top.
from beggining to end, i spent under $500.
Realquick-yes i did fix that miss, i put an MSD HVC 6600 box and coil on it, ran awesome till i had bearing failure in one of my turbos...so shes sitting lonely in the garage now untill i can afford some turbonetics units.
Old Mar 21, 2007 | 04:54 PM
  #49
LT1-TA's Avatar
Well it is majorly a street car.... but put together to be beat on.... Would like it to drive and run like a stock car and open up into the animal it should be. Want part throttle to run decent... idel should be easy enough... decel probly will suck a bit... if i venture to do it I want it to work as good as the factory comp did... or I will jsut use what i have till i save for the new MSD efi or soemthing...
So whats the run down on getting it all setup then... What needs to be done and what are the specifics for getting it all setup on the lt1? Thanks a lot man!
Oh... and right now i have a mallory 685 box.... point in keeping it?
Old Mar 21, 2007 | 09:20 PM
  #50
will62085's Avatar
i would keep the ignition box...your gonna need one as the VB921 ignition coil driver is not strong enough for high HP applications alone...you need its output signal to trigger some type of ignition box for a stronger spark.
for driveability purposes, the smaller your injector, the better. As duty cycle goes up, your resolution will increase. I have some driveability issues only on the highway in 6th gear, under 2k rpm...with my 160 lb/hr. injectors.
basically what you need to do is hook the signal side of your obdII crank sensor to the trigger input of the MSII. When your making the MS, make sure you build the hall sensor circuit. PM me once you get this far and ill tell you what settings to use in megatune to make it all work.
Old Mar 21, 2007 | 10:26 PM
  #51
LT1-TA's Avatar
well i aint gunna make it... **** that.... i am buying the complete one....
Old Mar 21, 2007 | 11:07 PM
  #52
will62085's Avatar
ahh come on...making it is half the fun...plus...if something breaks, you will know how to fix it.
Old Mar 22, 2007 | 12:35 PM
  #53
LT1-TA's Avatar
ive never even held a soldering iron.. lol... probly a bad idea
Old Mar 22, 2007 | 08:57 PM
  #54
will62085's Avatar
you can build a sweet turbo setup...and you are afraid of soldering? come on... ...its really easy...i learned to solder when i was like 8 years old
Old Mar 23, 2007 | 02:12 PM
  #55
LT1-TA's Avatar
well if I find a buyer for my OBD II pcm... My OBDI conversion pcm.... my tuner cats and cables.... i will probly do it...
Old Mar 24, 2007 | 02:04 AM
  #56
Kelly.'s Avatar
pm me what you are looking to get for your tunercat/cables setup
i may be able to help you get the MS.
Old Mar 25, 2007 | 07:39 PM
  #57
LT1-TA's Avatar
Well.... pm and let me know what your thinkin...And depends on all what you want.
Old Apr 11, 2007 | 12:45 AM
  #58
LT1-TA's Avatar
Would you say MSII or jsut MS? Im leaning towards MS with all the goodies...
And on top of that everyone is telling me i will be happier with MS
Old Apr 11, 2007 | 11:11 AM
  #59
will62085's Avatar
whos everyone? The higher resolution alone on both the fuel and timing tables is worth going with MSII. What do you want that it does not offer?
Old Apr 11, 2007 | 01:18 PM
  #60
LT1-TA's Avatar
Uhh... most the people i have talked to on the net. The guy who did most the work on my car. lot of people are saying to go with it.
You tell me the resolution of MSII... because MS can be the same.
12x12 Volumetric Efficiency (VE) and Ignition Tables
then there are TONS of add ons for the MS... just seems like the better choice at this point in time.
