Turbo 355 rod question
I just started my turbo 355 lt1 build up.
Right now is
freeze plugs
4 bolt main
eagle crank
Je turbo pistions and rings
My question is iam looking to make some where in the 600-700hp range on a t-70 rear mount. What rods should i use
eagle i or h beams
5.7 or 6.0
Right now is
freeze plugs
4 bolt main
eagle crank
eagle i or h beams
5.7 or 6.0
Compstar>>>>>Eagle. The 5.7 rod is the best bet for a blower setup. Well, the best may be 5.875" but the difference is marginal and the cost is quite a bit higher as it is an "odd" size. H v. I beam is a meaningless distinction.
Rich
BTW: you might get more response in the correct section, Forced Induction.
Rich
Lt1son
Dec 31, 2014 01:35 PM
Hurin
Dec 13, 2014 07:38 PM
