Turbo 355 rod question
Old Dec 16, 2007 | 10:00 AM
blackz151's Avatar
I just started my turbo 355 lt1 build up.
Right now is
freeze plugs
4 bolt main
eagle crank
Je turbo pistions and rings
My question is iam looking to make some where in the 600-700hp range on a t-70 rear mount. What rods should i use
eagle i or h beams
5.7 or 6.0
Old Dec 16, 2007 | 01:35 PM
rskrause's Avatar
Moderator
Compstar>>>>>Eagle. The 5.7 rod is the best bet for a blower setup. Well, the best may be 5.875" but the difference is marginal and the cost is quite a bit higher as it is an "odd" size. H v. I beam is a meaningless distinction.
Rich
BTW: you might get more response in the correct section, Forced Induction.
Old Dec 16, 2007 | 07:41 PM
F.I.94z's Avatar
I am running a 6.0 eagle H beam. I am not sure if one is better 5.7 or 6.0 but that is what I am running
Old Dec 17, 2007 | 09:31 AM
RealQuick's Avatar
To answer your specific question, I would get the Eagle H-beam over the I-beam.
Are there better rods out there than Eagle, yeah. Is 700hp too much for an Eagle H-beam rod... no.
Old Dec 17, 2007 | 09:49 AM
jsetzer's Avatar
Ditto - 5.7 eagle h beams here.
Old Dec 19, 2007 | 10:52 PM
blackz151's Avatar
Now for pistons iam kinda set on je but is there any other choices out there? Before i decide
Old Dec 19, 2007 | 11:05 PM
RealQuick's Avatar
Ross and diamond are good ones too.
Old Dec 19, 2007 | 11:25 PM
blackz151's Avatar
ill take a look at ross
Old Dec 20, 2007 | 06:39 AM
97s10ondubs's Avatar
I just got a set of wiseco pistons that are made out of the same 2618 material that JE and Ross use for blower pistons. I saw a few ls1 guys running them with good results, so I'm going to give them a shot.
LeftoverChinese
Jan 14, 2024 03:03 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Hurin
Dec 13, 2014 07:38 PM
