Some S/C Parts Questions
Old Mar 13, 2004 | 11:12 AM
RealQuick's Avatar
I have a vortech S trim that I bought used (supposedly complete), but its missing some components. I looked at the manual and Vortech lists a MAP Sensor. Can I just use my stocker, or do I need it?
Also, the Vortech Crank pulley just bolts over the stock LT1 damper/crank pulley right? The directions say something about removing the balancer weight from original balancer and installing onto vortech balancer. I dont see a part number for this balancer though?
Old Mar 13, 2004 | 04:31 PM
boosted19's Avatar
Ok, first. My vortech I had came with the map sensor, but also came with the retard control ****...does your's have that? I mixed my stock map sensor up with the other one and it still worked...so not too sure on that...
Second, you are missing the balancer. I was missing mine with the powerdyne I just got and what I did was grind down the triangle and other b.s. that's raised up on the stock one. Also my powerdyne has a ring at the bottom of the pulley...I grinded that down too since it looks like that's supposed to fit inside of the powerdyne pulley...I can't remember if vortech is like that.
Old Mar 14, 2004 | 07:22 AM
RealQuick's Avatar
So I should have gotten a vortech pulley and balancer?
Old Mar 15, 2004 | 11:57 AM
blueta's Avatar
yes, you should have the vortech ballancer. However if you modify your stock one you'll be ok.
oldschool
Feb 9, 2016 09:21 PM
Queens94z28
Dec 20, 2014 09:11 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Hurin
Dec 13, 2014 07:38 PM
