Some other PTK kit pictures
Hey guys I took some pictures of the kit on my car. I took some things out of the way to get some better shots, so at least you can get a clear shot of what the kit looks like.
Still plenty of room even with the T88 againist the radiator.
PTE88
bottom of water tank...perfect fit.
crossover pipe, uses V-bands and flex section which is a very nice addition.
DP, exiting from 88, uses donut flange, I also have a 4" version using the V-band housing.
driver side
pass. side
Water/air IC, bigger then it looks, its bascially almost riding on the plastic cover behind it. Mine is a little larger version though then the normal street kit.
H.E. and Dual Spals
large water tank.
I decided to keep my battery up front so I made a bracket to mount under the water tank....its a dry cell dynabatt.
Jose
PTE88
driver side
pass. side
H.E. and Dual Spals
large water tank.
I decided to keep my battery up front so I made a bracket to mount under the water tank....its a dry cell dynabatt.Jose
Great pics!
It's amazing to see how similar those headers are to the ones i'm fabbing up. But, then again, it isn't like there are too many other options when it comes to routing.
I was wondering about the drainback you have, I can't quite tell but from the angle of the photo it looks like its going uphill. Do you think you'll have any problems?
Again, great looking setup!
Marty
Marty
96TurboTA, the crossover goes under the car and up to the header. The DP does down the driver side.
Geoff, I'm running the Tial 38mm since I'm not bleeding alot of boost. The outlet is pointing down cause the pipe coming from the IC comes from under the turbo. The setup fits very nicely.
Jose
Jose
Lookin good man. How about a few pics of the plugs/wire clearance on those headers? Also, did you have to do anything to the radiator/ac stuff to get the PT88 to fit in there?
Edit... Are you going to be selling those 4" down pipes?
I can change plugs in 30 mins max.
No the 4" is a custom piece, to difficult to duplicate. As for A/C, and radiator, nothing had to be moved except the fans, and the kit comes with Dual Spal pushers.
Jose
Jose
Jan 23, 2015 01:13 PM
CARiD
Jan 14, 2015 04:00 AM
