Single Turbo Guys....What exhaust.
Old Jan 11, 2008 | 09:27 AM
  #16
jsetzer's Avatar
None, my downpipe dumps into the fender where a cold air kit would go.
Old Jan 13, 2008 | 06:35 AM
  #17
Juiced91Z's Avatar
my down pipe is 5" off the turbo, about 18" it goes into a 4" and is run through the a-arm. I have coilover conversion, and tubular kmember/a-arms so this gives me alot more room to play with. At about where the cats are located (under the pass floor pan) is a magnaflow 4" race muffler and then another 1" section of straight pipe into a turn down.
Old Jan 13, 2008 | 09:26 AM
  #18
IROCThisZ28ForLife's Avatar
wow that must be LOUD, sounds bad *** probably though
Old Jan 17, 2009 | 06:50 PM
  #19
snorkelface's Avatar
Originally Posted by leadfoot94
Full 4" from the turbo with a Dynomax Race Bullet. Its actually not very loud which can be a good and a bad thing. I used ovalized pipe underneath to keep some ground clearance.
Is that Dynomax a 4" oval pipe muffler also?
Originally Posted by LS1Tommy
3" SLP 2OTL. Made decent HP through it. Any 3" or better w/o baffled mufflers will be sufficient for street use from a sound and power stand point.
That's the exhaust I have on my car and it isn't nearly enough. I'm losing about more than 1k RPM and ~200HP because the car falls right on its face in the upper RPMS. I'll be going with a 4" oval setup.
Old Jan 21, 2009 | 03:45 PM
  #20
leadfoot94's Avatar
No, it transisitions back to regular 4" after it goes underneath the low point of the car.
Old Jan 21, 2009 | 04:53 PM
  #21
Got it.
Old Jan 21, 2009 | 04:59 PM
  #22
ford's Avatar
i will be using a slp loud mouth. i used to have 3" true duals but i had alot of clearance issues where i live and i was often breaking mounting brackets from hitting. sadly i will be bolting on a cat for inspection day.
Old Jan 21, 2009 | 05:39 PM
  #23
I'm going to try and stuff the random tech 4" oval cat where the stock ones go. I need to check the dimensions to make sure it will fit!
Old Jan 21, 2009 | 08:26 PM
  #24
reamo04's Avatar
where did u buy the ovalized piping?
Old Jan 26, 2009 | 05:20 PM
  #25
leadfoot94's Avatar
Burns stainless. I think Dr.Gas sells it as well.
Old Jan 26, 2009 | 05:22 PM
  #26
1982z28with18s's Avatar
Originally Posted by 1982z28with18s
I run a custo m made 3" setup, it runs from the drivers side kmember straight back to the back of the tranny, does a 90 degree toward the passenger side, goes behind the tranny, another 90 degree to the back, and I have a 18" bullet, and it stops before the rear axle. The car is VERY quiet with this setup.
This setup worked great for me on the stock heads/cam and with the log manifold setup, but once I did a true header setup by RealQuick and heads/cam it was too loud. I just added a dynomax ultraflow after the bullet before the axle and it was quiet again, I prefer QUIET cars also.
Old Jan 28, 2009 | 12:02 PM
  #27
ford's Avatar
I plan on bolting in a off road pipe for the other 364 days a year though. I am worried about how loud the loudmouth is going to sound, but at the same time I ran open headers/y-pipe for a while.
football4life
Oct 4, 2015 07:48 AM
RX Speed Works
Oct 1, 2015 10:19 PM
95blkss
Sep 22, 2015 03:18 PM
cmsmith
Sep 14, 2015 09:09 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
