Single Turbo Guys....What exhaust.
Old Jan 9, 2008 | 04:34 PM
BLWNLT1's Avatar
What exhaust are you guys running? Also would it hurt if you set up your exhaust sort of like the GMMG exhaust but with 18" Sweet Thunders? Or will this be to restrictive?
Old Jan 9, 2008 | 07:49 PM
IROCThisZ28ForLife's Avatar
exhaust? people actualyl run exhaust after getting boosted???? j/k, i am curious as well as to flow from different cat backs...i would imagine they would/SHOULD be welded im assuming...I wonder what My magnaflow will sound like??
Old Jan 9, 2008 | 09:15 PM
1982z28with18s's Avatar
I run a custo m made 3" setup, it runs from the drivers side kmember straight back to the back of the tranny, does a 90 degree toward the passenger side, goes behind the tranny, another 90 degree to the back, and I have a 18" bullet, and it stops before the rear axle. The car is VERY quiet with this setup.
Old Jan 9, 2008 | 09:20 PM
leadfoot94's Avatar
Full 4" from the turbo with a Dynomax Race Bullet. Its actually not very loud which can be a good and a bad thing. I used ovalized pipe underneath to keep some ground clearance.
Old Jan 9, 2008 | 09:53 PM
Lead, you got any pics and where does your DP go past the kmember?
Old Jan 9, 2008 | 10:11 PM
nxfirebird's Avatar
very very quiet!
sounds stock!
Old Jan 9, 2008 | 10:24 PM
leadfoot94's Avatar
I don't have to worry about the K.
Old Jan 10, 2008 | 09:50 AM
97ChameleonTA's Avatar
Moderator
How do you not fry your fuel lines???
Old Jan 10, 2008 | 11:06 AM
c0rey's Avatar
Im running the 3 inch all the way back to a magnaflow cat back. There is a small video of it in my turbo build thread. Ill get better videos sometime very soon.
Old Jan 10, 2008 | 11:46 AM
Originally Posted by nxfirebird
very very quiet!
sounds stock!
Thanks, I forgot you saw it at the shootout. I have had a few people mistake it for a v6 also at idle/cruising, lol.
Old Jan 10, 2008 | 03:55 PM
leadfoot94's Avatar
They are tucked way back against the firewall, wrapped in heat tape, and covered in fiberglass heat reflective sleeves. Plus the Turbo Blanket helps keep a large majority of the heat down.
Old Jan 10, 2008 | 04:48 PM
is the vid your referrring to the teaser vid?
Old Jan 10, 2008 | 09:20 PM
c0rey's Avatar
Ya back to the topic. Magnaflow sounds good.
Old Jan 10, 2008 | 11:41 PM
You can hear my car here, I rev it as I go down the driveway so you can tell it's quiet. I was working on a wastegate issue this day. You can actually hear my SPAL fans over my exhaust at idle!
http://media.putfile.com/turbo-LT1-H...rdgen-fox-body
Old Jan 11, 2008 | 08:37 AM
LS1Tommy's Avatar
3" SLP 2OTL. Made decent HP through it. Any 3" or better w/o baffled mufflers will be sufficient for street use from a sound and power stand point.
