Pulley Help
Old Jun 14, 2004 | 11:26 PM
1984camaroz28's Avatar
Pulley Help
This Pulley
Will this pulley make 11Psi with a ati Prcharger p600 kit
Old Jun 14, 2004 | 11:53 PM
97WS6SCharged's Avatar
Depending on the size of the crank pulley it's possible. I like how he mentions that "it should work on any procharger". Yeah, it will fit any procharger, but will the offsets allow the belts to line up correctly?
Old Jun 15, 2004 | 05:43 AM
IDOXLR8's Avatar
Re: Pulley Help
Originally posted by 1984camaroz28
This Pulley
It really depends on your setup. It is hard to get 11lbs of boost out of a P600b on a built motor with good flowing heads.
Old Jun 15, 2004 | 07:25 AM
Lonnie Pavtis's Avatar
The Cobra uses 6 rib drive systems from the factory. What engine are you putting this on?
With your engine combo & pulley dimensions, I can get you close.
Old Jun 15, 2004 | 12:23 PM
its a 383 with 562/580 248/254 114 lobe sep Cam.. and trick flow heads
Old Jun 15, 2004 | 12:25 PM
Ati procharger . P600 Kit includes twin intercoolers , piping mounting brackets ect
Is 1500$ a good deal on this setup???
Old Jun 16, 2004 | 06:29 AM
IDOXLR8's Avatar
How many miles does the blower have on it. Is the 383 built for a blower ? If it is then I would not bother getting a P600b and probably step up to something a little bigger.
AviatorDave
Dec 19, 2016 06:35 PM
RUENUF
Mar 13, 2016 03:37 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Slayer
Aug 17, 2015 03:55 PM
