procharger belt size
Subscribe
Sep 15, 2004 | 03:07 PM
what size belt do I need for a p600b with a 2.65 pulley and 7 crank pulley. I broke mine last night and cant find the belt to match it. it is a 8rib setup. I need to know the inches for it
Reply
Sep 15, 2004 | 03:44 PM
Re: procharger belt size
When I had the a P600B on the car with the same size pullies (except 12rib) the belt part# was K120400 So a 12 rib 40 in. belt. I have found replacement belts at Napa and Carquest as they are both Gates retailers.
Hope this helps
J
Reply
Sep 15, 2004 | 04:43 PM
I am running a 2.55" charger pulley, 7.5" crank pulley, and 2 - 2.3" idler pullies on my p600b (8 rib setup). Procharger told me to run a 57" belt. I found I need a 56 and 5/8" belt to work to be able to tension it down. Anything bigger and it rubs on itself where it comes around the charger pulley. I have about 1/2" clearance and am able to get 12 pounds with no belt trouble (slippage, rubbing etc). It took me a few tries at $30-$35 a clip for the belts. Also, I get my belts at napa. The part# for the 56 5/8" is 080560 and 080565 for the 57" belt. I hope this helps you. Good luck
Reply
Subscribe
