Powerdyne Intercooler?
Old Aug 14, 2003 | 06:03 PM
Rice-X's Avatar
I know there's none available through powerdyne but is there any intercooler that could work with the powerdyne without alot of custom work?
Old Aug 14, 2003 | 07:28 PM
MislMan's Avatar
I haven't seen anything that would work with the PD set-up. I believe you could re-clock the head unit to point the discharge outlet in a different direction but I doubt that you would see a big gain in engine output (more lost to the pushing air through the intercooler than produced from the cooler charge). It might be worth more to add water/alcohol injection to cool the air charge during WOT operation. I'm sure Rick Krause could give you some good input on a water injection system.
Later ... Larry S.
Old Aug 15, 2003 | 12:02 AM
Rice-X's Avatar
aggie....i'd probalby be interested if i knew i could get it to work for sure. I just wounldn't want to be stuck with something i couldn't use . Anyone here tried that before or know if it can be done?
Old Aug 15, 2003 | 04:59 PM
engineermike's Avatar
The Vortech aftercooler would definitely be your best bet for ease of adaptability to the Powerdyne. On piece of "muffler pipe" MAY have to be modified to make it work. That will be easier than any air/air, even if the air/air is made to fit it.
Mike
RUENUF
Mar 13, 2016 03:37 PM
bunker
Jan 30, 2016 08:09 PM
HAWG
Sep 25, 2015 11:41 AM
