anyone using the 2.55 pulley for an ati p600b?
i know ati used to offer a 2.55 pulley but is anyone using one and....if so..do you have any problems with it... is there any upgrades that can be done to the supercharger like a 10 or 12 rib pulley.. setup. does anyone make a kit or..have pullies that would work on a p600b..i just want to get the most out of that blower.
Steve
Steve
There 12 and 15# pullies are 12 rib and the 8# is 8 rib.
The biggest advantage for the 600B is through more airflow and not necesarrily more blower rpms. Get a good 3.5 or 4" intake on the blower and there will be a big difference in blower performance.
heh watch this pulley not work..i had a p600b with a 8 psi pulley. they sent me out a pulley...i'll prob have to change everythin now..i guess i wont know till i try it out..thanks for the info
Steve
Steve
ok here is the scoop. I am running the 2.55" pulley (15# pulley). I make a solid 12 pounds due to opening the air flow ie headers. It is an 8 rib set-up and it runs great!! The only thing to watch is to make sure locktite is used when installing the pulley. I had my s/c rebuilt last summer, because that pulley came off, so ATI advised locktite. They sent the s/c back with a loose pulley, so I put locktite on and tighened it up to around 75 ft pounds as ATI wouldn't give me a torque spec, but it has stayed put now for a couple thousand miles - like everything else just keep a close eye on it.
That's interesting..... when I had mine rebuilt they called me and asked me about the 2.55" pulley. They had to replace the pulley and wanted to know if I really wanted the 2.55". I said yes and they put a new one on. I confirmed it by measuring it when I got it back
yea...the pulley diameter is written right on the pulley.....they said they no longer ship the 2.55 ..i called them back....after seeing the pulley was 2.65...i..just emailed a company in reguards to a 2.55 pulley..hopefully they'll make me one..heh i was even wondering if theyd make a 2.50 pulley or somethin lol..i could keep a lower redline for the motor..and it make..good boost..without having to rev the motor to 6 grand etc
Steve
Steve
sleeperZ96BT
09-09-2015 08:28 AM
