map sensor question
As I am trying to get the tune dialed in on my car, The map sensor is one thing I keep coming back to wondering if I am having issues with it. as anything about about 15% throttle it goes to 1, is it common for a map to do that? is there anything that would create a better scenario to help the situation.:confused:
Thanks in advance for and help or suggestions. |
Originally Posted by LALT1
(Post 4400901)
car has a vacuum/boost gauge in it. so should the map not go past 1 until it at least comes out of vacuum?? a little confused here.
(Post 4400957)
When your vacuum guage reads 0 or is in boost your map should be pegged out at 100 KPA or 30 inches. If vacuum reads 12 inches then MAP should read ~18inches. The sum of the two should always equal ~30inches. :) |
yes sir, 100 was what I was getting at, sorry about that.
what are you using to scan it?
in datamaster it shows you what the pressure is before you start it... whats that reading? also your not looking at that instead of the live data are you? |
| All times are GMT -5. The time now is 06:52 AM. |
