Manual vs Electronic Boost controllers...
____After dynoing the initial setup at 11psi on the spring, the dyno operator told me I needed a boost controller. So, I did some quick research and found that the price/benefit/recommendations dictated something like the AEM Truboost since I liked the variability of it, multiple customer preset boost levels, history(max boost attained) and other variabilities. I'd enjoyed it for the past 3 years but after swapping the transmissions a couple of times (I have a built TH350 and a heavy duty T56/Spec stage 4 setup), I noticed that the wastegate appeared to be opening too soon.
____Reading up about it, I found that there are two types of boost controllers (in general) "Bleeders" and "Gated". Most of you knowledgeable types are rolling your eyes and whispering "duh..". Well, in talking with Bryan Herter of PCM4Less tuning fame, he said he was a fan of Manuals because the boost ramps up more quickly, since they don't have a solenoid bleeding off pressure in a linear fashion, up to peak boost setting. ____With that in mind, I bought a Turbosmart manual (Boost Tee) and installed it, thinking "I'll just insert it where I had the solenoid for the AEM Truboost. What could be different?". Well, a lot actually. Where as the AEM setting was 15 psi and I have 14lbs spring in the wastegate, I thought I'd just set the Manual Boost Tee to the lowest setting possible and take her for a good old drive. Holy sh*t... 18psi every time. This confounded me for the past 3 months but I wasn't driving it much because it's the Winter and I'm in upstate NY. ____Finally, I went looking around in google for "Overboost Manual Boost Controller Turbosmart". I found several guys like myself, suffering from the same issue. So I finally went to Turbosmarts site and looked for help there. One of the links was the install .pdf (The device came with a mini-dvd of instructions but my Netbook doesn't have a dvd/cd drive so it was useless). Well I'll be. There it is in the .pdf. ____You can't hook it up the same as the AEM Truboost. You have to pipe the pressure point (outlet of Turbo for me) straight to the Boost Tee with nothing else on that line, then from the boost Tee port labeled "Wastegate" to the BOTTOM of the two Waste gate ports (Leaving the top port to 'vent to atmosphere'). I just got everything rerouted and took her for a test drive. 14.5 PSI on the lowest setting. Much better. ____Yesterday, before I got this rerouted, I was on the freeway when a Turbo WRX Subaru drifted up the on-ramp and got beside me. I thought, "hmmm.. I wonder... He looks young so maybe...", but he didn't do anything right away. We were more or less in proximity to each other for the next 3 miles, then we both ended up taking the same ramp to another freeway. As I slowly moved up closer to him as we made it thru traffic at last, we were going about 55mph. I was in 5th.. then, while he's still out about 2 cars ahead of me, he hits the gas. I fumble for the shifter, and downshift to 4th and floor it. Third would have had me leaping up on him but I thought, "ah well, let's just wind out in fourth and see..". Once I got up into some decent boost, I pulled hard up on him but he let off right as I pulled beside him. I tried to get his attention to let us drop down to about 40 and do the 3 honks thing but the guy wouldn't look at me for nothing. For the next 3 miles I tried to get him to look at me. Lol.. Ah well. ____I then punched the 'History button' on the AEM TruBoost (even the manual is in the circuit, the AEM truboost still monitors manifold pressure). Yikes! 18.9psi.... ____Even at the current sub 15psi, the car has me shaking from adrenaline when I wind it out fully in 3rd and 4th gears. Love Turbos!!! |
Re: Manual vs Electronic Boost controllers...
Nice Dave! I was talking with Jason Short over the weekend, and he commented on how strong your car felt when you took him for a ride. Now... when will you let me really build you something sick? My offer still stands for you pay the price for materials and I'll fab for free.
That was nice of Jason :) I'm sure he's been in quicker/faster cars.
I would love to take you up on your offer. I just have to see how my next contract works out. I'm just finishing up (March 15th) with the current contract. I may be waiting for a month or two before the next one picks up. Once I have that offer firmly in hand, then, sure. :) What do you have in mind anyway? My own ideas are either an 88 or twin 58mm. Just not sure yet. :) Thanks for everything. You've been great all along, even though you've had some things go less than optimal in things unrelated to Turbo's/welding, you've never let it affect you and always came through and then some. By the way, I still have those beautiful 1/2" thick CNC cut mild steel flanges I bought from a bud on this forum. I can forward those on to you when the time comes.
Originally Posted by RealQuick
(Post 6883108)
Originally Posted by DirtyDaveW
(Post 6883196)
I would love to take you up on your offer. I just have to see how my next contract works out. I'm just finishing up (March 15th) with the current contract. I may be waiting for a month or two before the next one picks up. Once I have that offer firmly in hand, then, sure. :) What do you have in mind anyway? My own ideas are either an 88 or twin 58mm. Just not sure yet. :) Thanks for everything. You've been great all along, even though you've had some things go less than optimal in things unrelated to Turbo's/welding, you've never let it affect you and always came through and then some. By the way, I still have those beautiful 1/2" thick CNC cut mild steel flanges I bought from a bud on this forum. I can forward those on to you when the time comes. Whatever you want to do is fine... depends on your goals and then we can go from there. |
That would be fun! An "Albany vs Rochester" battle! I have one thing in my favor if it's at the drags. A TH350 w/4000 stall Torque converter and a 2-step. Maybe a transbrake too. If he just wants to go 3 honks on the freeway, I'll keep the 6 speed :) No matter what, it would be great fun!
Goals. Well, the crank can handle 1000hp but the rods only 800. Also, I know you can only get x HP to the ground without slicks so I suppose my main goal would be getting into boost as quick as possible off idle. That sounds like Ball Bearing Twin 58's to me. Otherwise, to go with the 88, I'd have to add N2O to get out of the hole quickly.
(Post 6883209)
Jason says he is gonna slap the taste out of your mouth when his car gets running :p J/K
(Post 6883248)
Email me if you want to discuss your goals and possible setups jon@lt1boost.net |
| All times are GMT -5. The time now is 05:37 AM. |
