MAF location
Old 10-25-2017, 06:35 PM
Z28ELECTRICIAN's Avatar
MAF location
I am wanting to go from a bypass valve to a Tial BOV. In order to do this I need to move the MAF to the charge side instead of where is currently located on the inlet side. Any negative concerms with relocating the MAF?.
Z28ELECTRICIAN is offline
Old 10-27-2017, 08:17 PM
Super Moderator
JakeRobb's Avatar
Re: MAF location
Potentially. What vehicle/engine?
It’s important that the flow over the MAF is not turbulent. It shouldn’t be too close to the air filter or any bends.
You might also consider switching to a speed density tune, eliminating the MAF altogether.
JakeRobb is offline
Old 10-27-2017, 10:18 PM
Re: MAF location
https://www.camaroz28.com/forums/lt1...nature-879835/
Injuneer is online now
Old 10-28-2017, 07:14 AM
Re: MAF location
Sorry I'm not sure why my signature didnt show up, it always has before.
96 LT1 camaro with a vortech supercharger. Currently tuned to OBD1 using tuner cats
Signature
96 Z28, LT1 355CI, Vortech Supercharger 10lbs,Alki injected, 6speed, Comp Cam 224/236/114, stage 3 heads, Crane Ign, Ed Wrigt PCM, Scan Master, 1.6 Roller Rocker,3" Exh No Cats, Strange 12 bolt 3.73, Adj suspension.
Old 10-29-2017, 06:26 PM
David94TA's Avatar
Re: MAF location
I descreened mine and located it just before the Procharger 90 degree inlet tube that goes to the intake. I had to get 3 1/2" to 3" reducer fittings for each end of the MAF. Mine works fine--idles and runs good.
David94TA is offline
