Is an intercooler really necessary?
I'm goin to be running an 1/8th mile and plan on water/methanol injection so is there really any point in running an intercooler? It's a track only car. What would be the benefits of running one and the downsides of not running one?
I was always told to run both. The only downside to an air to air intercooler is more complexity, more weight, more piping lose, pressure lose through the core. However, the advantages of a denser charge out weigh all of that.
Meth or water or a mix is good for gaseous intercooling as well. Meth adds a higher octane fuel. Some consider these to be more hazardous because of complexity of the system (like failing to turn on).
I'm running hot air. Probably just going to add injection as well.
-Scott.
-Scott.
I was thinking about trying to get my without and A2A and then maybe if I decide I need one fab up an air to water IC. How much hp do you think I will leave on the table not running one? I'm going to be around 8.5 to 1 on compression with the trickflows.
If that doesn't bother you, then I agree, A2W is best.
i think i paid 200 for my a2a kit. one of the biggest a2a intercoolers as well. Plus if you want cooler after that, run a co2 spray bar on it.
Any opinions on this kit?
http://www.frozenboost.com/product_i...a9b9e231fb6248
It highly depends on the intercooler design. But, the tiny avenger project gained 10-15% by going from air/air to water/air.
RUENUF
Mar 13, 2016 03:37 PM
96SilverRam
Jul 15, 2015 12:31 AM
