CamaroZ28.Com Message Board
-   Forced Induction (https://www.camaroz28.com/forums/forced-induction-10/)
-   -   hp estimate (https://www.camaroz28.com/forums/forced-induction-10/hp-estimate-484847/)
racer96 Nov 15, 2006 07:15 PM
hp estimate
i am gonna need for a fuel system. ill give you everything i know about the setup.
383 stroker block out of a 94 z
lunati forged h beams and crank
je blower pistons 8.25 compression
high volume oil pump
electric water pump
comp cam special grind 236/248 579/579 114
lt4 intake
lt4 heads bee hive springs 1.6 rr
d1sc procharger twin high flows gonna run around 20 psi hopefully
headers full loudmouth exhaust
will be getting a dana60 hopefully it is quiet hahah
full suspension
spec stage 4
any help is appreciated, or fuel systems i would like the most out of this setup and will push it hard! thanks guys
ramermanz28 Nov 15, 2006 09:16 PM
Don't skimp on the fuel system or you'll pay, trust me I know. Spend alot of time on the fuel system.
racer96 Nov 15, 2006 10:43 PM
yes i had bought this engine off a board meber. it is all brand new, should i get new heads or new pistons. how hard would it be to get new pistons in there. the engine is in a crate still.
roguedriver Nov 15, 2006 11:02 PM
I would imagine a dual in tank pump setup like the Racetronix dual 255's, 60# injectors, a good regulator and stock fuel lines should be sufficent with some room to breathe.
Ken R.
racer96 Nov 15, 2006 11:42 PM
i cant find the racetronix dual 255's is there a link or can some one give me a link thanks.
ZBLKHELLRZR Nov 16, 2006 01:05 AM
Here you go. Select racetronix on the left of the screen.
http://www.lonniesperformance.com/
CrazyLT1 Nov 16, 2006 09:24 AM
With that set-up, running correctly, your prolly lookin at 650-700 RWHP
racer96 Nov 16, 2006 12:18 PM
thanks for the link, i hope i am in that horsepower, thats what i where i would like to be!
TransAm396 Nov 16, 2006 08:35 PM
......20psi on beehives?? good luck with that one.
racer96 Nov 16, 2006 09:15 PM
Originally Posted by mgray (Post 4230086)
Is it in writing or verbatum this 8.25 compression ratio?
thjat is what he told me the other day, i am going to call the guy and ge the exact part number of the pistons. 8.25 seems very low. i see some guys running lower but i dunno i hope it is around 9:1.
racer96 Nov 16, 2006 09:16 PM
ya i think i am going to run 15 psi. i thought u could run more on pump gas but it should get me close to my goals.
Kredz28 Nov 17, 2006 09:42 AM
i would ditch the high flows if you are going to run more than 15psi...
CALL911 Nov 17, 2006 12:51 PM
Agreed. After about 8#'s or so, the twins just can't keep up. I highly reccomend a FMIC. Or if nothing else, look into running a methanol injection system or race gas.
Properly setup though, if you max out the D1SC (my guess is that you won't see over 18#'s of boost), with the setup you said, properly tuned, it should do an easy 650-700 RWHP if not more.
Also, if possible, you may want to consider going with a FAST system to properly run everything.
BTW, I dyno'd my car at 15.3#'s of boost, and it was all done with pump gas on the stock PCM. If I had the FAST system in place of the PCM, I could have run more boost, and without a doubt gained more HP, still running off of pump gas. Video of my tune here>
http://thumbs.vidiac.com/5d911306-59...2b00ebf51d.jpgClick here to see Video
