How do you know when your going into boost ?
Old Jun 4, 2004 | 04:35 AM
bowtiepwr's Avatar
Question How do you know when your going into boost ?
>I have a vaccuum / boost gauge from Autometer and it seems to just register the vaccuum and not the boost . The car sems really strong , but I was wondering if it was just all motor . I plan to remove the S/C belt and try it that way to see if it is any different .
Old Jun 4, 2004 | 04:39 AM
97WS6SCharged's Avatar
The boost needle goes one way, and the gas needle goes the other.
Old Jun 4, 2004 | 04:54 AM
SMOKNZ's Avatar
First make sure your boost gauge is plumbed into the intake manifold. Then you find a nice long peice of open road and you pin the throttle to the ground. If there are no leaks in the line from the manifold to the gauge there should be some boost especially in the higher RPMs. That is if your belt is not slipping and all the intake plumbing is on tight.
Old Jun 4, 2004 | 07:26 AM
MEAN LT1's Avatar
Re: How do you know when your going into boost ?
Heh.....you feel the "hand of god" start to push the car more and more as the rpms increase. Its a pretty cool feeling.
Old Jun 4, 2004 | 08:02 AM
IDOXLR8's Avatar
Re: Re: How do you know when your going into boost ?
LMAO
Old Jun 4, 2004 | 08:16 AM
Acct 23749's Avatar
Try this...pump air or even blow air into the boost gauge tube...see if it goes up, just with my lungs i can move the gauge to like 2 or 3 psi... Its unlikely that the gauge is bad tho....Where do you have in plugged? make sure its not an opti line, those sometimes have one way valves on them
Old Jun 4, 2004 | 09:14 AM
IDOXLR8's Avatar
Also when your car is off. What does your boost gauge read? It should be 0 if not your gauge is not calibrated properly.
Old Jun 4, 2004 | 11:12 AM
1st and goal's Avatar
You've got to be kidding me
There is a big difference between "really strong" and "smack you in the a$$"
aka - Really strong - all motor
Smack you in the a$$ - BOOST
I ran my Z for a while last fall as I got tired of throwing belts and it went "OK" but you should be sporting a chubba if you get into boost
Do you hear a whistling noise?
Are you running a fast system or modified PCM?
Who's doing your tuning?
Are you going to Camaro day at New England Dragway tomorrow?
If so I'l go for a spin and evaluate boost / no boost
Marc
P.S. Like the "hand of God" comment
Old Jun 4, 2004 | 02:09 PM
bowtiepwr's Avatar
>cool
I read the boost / vaccuum gauge at idle and it indicated 19" of vaccuum and it never indicated positive psi (boost) , but when the engine is turned off the gauge indicates 0 .
I plan to remove the S/C belt to see how it drives , and of course reinstall it .
Old Jun 4, 2004 | 05:46 PM
SMOKNZ's Avatar
It's not going to read boost at idle
Old Jun 4, 2004 | 06:59 PM
texlurch's Avatar
I have a digital one that reads vacuum and boost, it never does anything to let you know what it is reading, but I usually know when the boost comes on since that is also when countersteer is required!
It will read like 6 or 7 when just putting around, then start to drop when you get on it, but then start counting back up pretty quick.
Old Jun 5, 2004 | 03:57 AM
bowtiepwr's Avatar
>thanks
RUENUF
Mar 13, 2016 03:37 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
96SilverRam
Sep 7, 2015 10:51 PM
Henson071
Aug 4, 2015 09:32 AM
